MrMagoo
#1 Posted : Sunday, July 13, 2025 1:11:57 PM(UTC)
MrMagoo
Has anyone successfully worked out a way to input TikTok (particular a live TikTok) as a source input into vMix?
If so, could you please share, thanks.
nikosman88
#2 Posted : Sunday, July 13, 2025 7:08:28 PM(UTC)
nikosman88
Greece
Add input-->browser if you manage to do login,or either a windows browser input and then add input-->desktop capture. Vmix 28 support browser window with combination "application audio"/system audio work very good
thanks 1 user thanked nikosman88 for this useful post.
MrMagoo on 7/16/2025(UTC)
mavik
#3 Posted : Monday, July 14, 2025 8:09:18 PM(UTC)
mavik
If you wanna capture from a mobile there are several options to cast the screen over the network. Even a Barco clickShare option would do. But the most easy is with a browser source like mentioned already.
