Avnishv
#1 Posted : Sunday, June 22, 2025 8:51:03 AM(UTC)
Avnishv
I have recently rebuilt my pc to windows 11 from windows 10 and have been getting random distortions/cracks and pops randomly mid way through my production, i have used this same setup in windows 10 with no issues but now after rebuild the latest drivers direct from the m audio website has been isntalled.
i have searched the web and everything is matching i.e. bit rate and KHz i am unable to change it the sound resolution in vmix. anyone else faced this issue with audio inputs after updating to windows 11?
My audio is clean also i can listen to the output that the M-audio device is sending to the computer and there is no disprtion/cracks and pops in that only when the computer is processing it and sending it out.
nikosman88
#2 Posted : Sunday, June 22, 2025 6:15:17 PM(UTC)
nikosman88
Greece
Hi. So the problem is only on Vmix? Do you have the latest version vmix 28?
You can send vmix support https://www.vmix.com/contact-us.aspx
