Piflik
#1 Posted : Tuesday, June 17, 2025 6:31:14 PM(UTC)
Piflik
For a current project I would need some additions to the API, specifically the XML string for the current state of the software:
  1. Hidden Layers: Currently, all layers are included as children of an input, regardless of if they are hidden or not, and there is no attribute for the "hidden" status. This should either be added as an attribute, or hidden layers should be omitted from the list, just like empty layers are.
  2. Source aspect ratio: since cropping is normalized and applied to the source resolution (even though the UI shows pixels, always in the output resolution), the resolution of a source, or, at the minimum, its aspect ratio, should be included somewhere in the API. This would allow apps that make use of the API to correctly calculate information that relies on cropping of a source. Currently this is impossible without first opening the source and extracting the resolution or aspect ratio.
ryxyz
#2 Posted : Friday, June 20, 2025 12:46:57 AM(UTC)
ryxyz
Was thanked: 20 time(s) in 6 post(s)
+1
