geoffroy
#1 Posted : Wednesday, June 11, 2025 6:32:38 PM(UTC)
geoffroy
We need to install vmiw 28 but it does not work because it requires a license validation, but we did not have this problem with version 27.
How can we pass this screen. If we can't do it we will use a another software
vmixgreg
#2 Posted : Wednesday, June 11, 2025 8:54:15 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
To activate vMix 28 you will most likely need to login to your vMix Account to deactivate one of your vMix 27 activations to make room for a new activation:
https://account.vmix.com/
vMix Greg
geoffroy
#3 Posted : Wednesday, June 11, 2025 10:15:09 PM(UTC)
geoffroy
Thx for the reply
I am the IT administrator and I need to install VMIX on 800 workstations in silent mode via python but I cannot get past the license window.
WaltG12
#4 Posted : Thursday, June 12, 2025 2:25:32 AM(UTC)
WaltG12
You get up to 2 activations per license.
Each new whole-number version counts as a new activation.
I don't know what you've done in the past or haven't done in the past.
But if you went from v26 to v27, the v26 activations don't automatically clear. You need to log in and remove them.
If you haven't done that, then you can't add a third activation, be it a new machine or a new whole-number version (v28).
If you're already only at 1 activation (or 0) per license, then you need to say that, because you're not really providing any information anyone can actually use to help you.
geoffroy
#5 Posted : Thursday, June 19, 2025 5:16:11 PM(UTC)
geoffroy
At past i install VmiW with this arguments
/VERYSILENT /SUPPRESSMSGBOXES /NORESTART /CLOSEAPPLICATIONS /SP- -Wait -NoNewWindow
with Vmix 28 this arguments don't work. I need a silent install for a school si i need to pass this screen.
geoffroy
#6 Posted : Wednesday, July 2, 2025 7:30:18 PM(UTC)
geoffroy
Can i have a support for this request please?
Ben-vMix
#7 Posted : Friday, July 4, 2025 9:18:36 AM(UTC)
Ben-vMix
Rank: Staff
Hi Geoffroy,
Due to changes in the End User License Agreement (EULA) for vMix 28, the agreement needs to be accepted manually. Unfortunately, this means it cannot be pre-approved or bypassed, as explicit user agreement is required.
geoffroy
#8 Posted : Friday, July 4, 2025 5:15:20 PM(UTC)
geoffroy
OK thx for your reply. So we will not use it for a school.
spinfold
#9 Posted : Saturday, July 5, 2025 6:40:34 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: geoffroy Go to Quoted Post
Thx for the reply
I just don't understand why you need vMix on 800 PCs in a school. It's specialist software which is designed to run on high end systems in professional broadcasting or streaming environments, not as general software on every possible machine.
If you genuinely have a use for 800 instances of vMix - and therefore have 800 paid-for licenses - then you can spend the time installing them all (as you will need to configure each one after it's installed anyway).
If you don't have 800 licenses then your users will have issues each time they load the software as they will need to deactivate licenses elsewhere each time, which will be more ongoing effort for you than the one-off manual installation.
And if you are already so heavily invested in the vMix ecosystem, have hundreds of thousands of £$€ invested in v27 already, and are simply trying to mass upgrade them all, then you wouldn't be so quickly dismissive of "ok we will not use it" any more.
thanks 1 user thanked spinfold for this useful post.
doggy on 7/5/2025(UTC)
mavik
#10 Posted : Monday, July 7, 2025 6:47:22 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Have you tried vMix support. I bet they are more than happy to support a 800 license client.
nikosman88
#11 Posted : Monday, July 7, 2025 11:40:21 PM(UTC)
nikosman88
Greece
So you will drop at least about 500k on garbage. This seems logic
