KCPro
#1 Posted : Thursday, February 5, 2015 11:16:19 PM(UTC)
KCPro
I am considering adding a laptop for use with a Magewell 4000 HDMI Card.
Can anyone recommend the best Windows Laptop with Thunderbolt for this purpose.
Speegs
#2 Posted : Saturday, February 7, 2015 4:03:55 AM(UTC)
Speegs
I'm using Macbook Pro 15" running Windows via Bootcamp (The hardware in the Macs is quite good). I have 2. When I purchased the hardware wasn't sure I wasn't going to use wirecast or Vmix, but after a no time flat decided to go Vmix. I couldn't find a PC with twin thunderbolt ports back then. Still hard. I use Magewell USB 3 capture devices (Primarily on my laptop), Black Magic Mini Recorders and most recently added one of these to get more ports: http://www.belkin.com/au/p/P-F4U085/ so I can have more full speed usb 3 ports than the macbook pro provides.
If I had a chance to start over and buy again I'd give this some serious thought (HAVE NOT TRIED IT, but I want to, already spent my money):
http://www.dell.com/au/b...ion-m3800-workstation/pd
Plus a thunderbolt PCIe Enclosure. Which is what it looks like you are interested in.
For all the Mac haters, they run Windows quite well via Bootcamp :) For quite a while it has been very hard to get a native Windows Laptop with the nice hardware of a Macbook Pro. That's changed recently.
vMixSystems
#3 Posted : Monday, February 9, 2015 12:38:31 PM(UTC)
Rank: Guest
Groups: Guests
If you visit the vMix Thunder page, there is a compatibility guide that essentially shows most of the current Thunderbolt equipped PC-based laptops. It also has a breakdown on which are v1 vs v2 and which graphics card they support.
Thanks,
Ken Bell - StudioCoast Systems
