podshopstudios
#1 Posted : Monday, June 2, 2025 5:42:02 PM(UTC)
podshopstudios
Hey all, we've recently put in a QNAP NAS server and 10gb/s enabled network to connect vMix to said NAS and a few other devices. The plan was to record the multicorder straigth to the NAS in a certain folder, but it's coming back with this error;
Screenshot 2025-06-02 083615.png (94kb) downloaded 45 time(s).
Has anyone else set this up or had similar issues?
Thanks in advance!
spinfold
#2 Posted : Monday, June 2, 2025 6:24:49 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
You could try mounting a root folder of QNAP as a drive letter in Windows.
However writing to QNAP "live" is probably not recommended, as it might not be stable enough to get solid recordings. Best to record to an actual local hard drive first then transfer to QNAP once the recording has stopped and finalised.
NiBTour
#3 Posted : Sunday, August 3, 2025 6:50:32 AM(UTC)
NiBTour
we do this with much success but we do it over a iSCSI connection to the QNAP. It as far as the OS is concerned is a local drive. Otherwise simply create a SMB share and use the drive letter instead of the network name.
