vmix786
#1 Posted : Monday, June 2, 2025 4:55:48 AM(UTC)
vmix786
i am researching the best webcam for video calls, streaming, and remote work, and the logitech c920 hd 1080p webcam kept popping up. i read reviews on the verge, pcmag, and techradar, and they’re all still mentioning it as one of the best options available.
two models keep showing up as top picks:
logitech c920x hd pro webcam
https://www.amazon.com/logitech-c920x-pro-hd-webcam/dp/b085tff7m1
logitech brio 501 full hd webcam
https://www.amazon.com/logitech-correction-auto-framing-reduction-microsoft/dp/b09whtmf23
i’m mainly using a webcam for video conferencing, occasional streaming, online classes, and maybe some youtube content. i need good low-light performance, clear audio, and reliable autofocus.
the c920 is definitely more affordable now than when it first launched, but i’m wondering if it’s still the best value for the price in 2025. should i invest in the newer streamcam or another model instead?
i’d appreciate any recommendations or advice you have on which one would best suit my needs. thanks in advance
