Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
When using the API to turn on and off bus selection, is the value limited to one bus at a time or can I put in multiple selections, EG value:="MAB" or perhaps value:="M,A,B"
UPDATE, I did a little experiment and it appears that it just takes a single bus value at a time. Can anyone confirm this?
Thanks,
Fritz Golman RadioDNA
