streamfuchs
#1 Posted : Friday, May 9, 2025 8:23:17 AM(UTC)
streamfuchs
Views messages in topic : 4
Germany
I am just new to this forum and I hope that some experienced scripting users can help me with a problem I am not able to solve.
I found in VMix-Wiki a very interesting solution to realize a quadsplitt tallylight.
It uses a gtzip template as an overlay to a multiviewer quadsplitt and a script to change text and colour of the overlay, depending on which input is active.
This works pretty good but only with inputs which are directly switched to the main output.
I would like to extend the capability to inputs which are used as an overlay source on the main output.
I am a scripting beginner and tried the whole day to find a solution without any success.
Here is the script, which is doing well with the directly switched input:
do while true
Dim doc As New XmlDocument()
doc.LoadXml(API.Xml)
Dim root As XmlNode = doc.DocumentElement
Dim node As XmlNode = root.SelectSingleNode("/vmix/active")
Dim inputNumber as Integer = node.InnerXml
If inputNumber = 1 Then
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOL.Text") = "Kamera 1 ONAIR"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOR.Text") = "Kamera 2"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUL.Text") = "Kamera 3"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUR.Text") = "PGM K1"
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG1.Text",Value:="red")
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG2.Text",Value:="black")
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG3.Text",Value:="black")
'API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG4.Text",Value:="black")
end if
If inputNumber = 2 Then
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOL.Text") = "Kamera 1"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOR.Text") = "Kamera 2 ONAIR"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUR.Text") = "PGM K2"
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG1.Text",Value:="black")
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG2.Text",Value:="red")
end if
If inputNumber = 3 Then
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUL.Text") = "Kamera 3 ONAIR"
Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUR.Text") = "PGM K3"
API.Function("SetTextColour",Input:="Quadsplitt_Rotlicht.gtzip",SelectedName:="HG3.Text",Value:="red")
end if
sleep (200)
loop
For input e.g. 26 the corresponding node in the vmix API XML-File is
<active>26</active>
for the same input on lets say overlay 1 it is:
<overlays>
<overlay number="1">26</overlay>
<overlay number="2"/>
<overlay number="3"/>
<overlay number="4"/>
<overlay number="5"/>
<overlay number="6"/>
<overlay number="7"/>
<overlay number="8"/>
Is there any good idea how to change the script to meet the overlay needs?
I do not know whether it is possible within one script for active and overlay or whether it is easier to have two ore more scripts or whether it is possible at all.
Any help is very appreciated.
nikosman88
#2 Posted : Friday, May 9, 2025 9:16:21 PM(UTC)
nikosman88
Greece
Hi. A script template for overlay 1 channel
Code:
Do While True
    doc.LoadXml(API.XML())
    ' Πάρε το input που είναι στο Overlay 1
    Dim overlayNode As XmlNode = root.SelectSingleNode("//overlay[@number='1']")
    Dim overlayInput As Integer = -1
    If overlayNode IsNot Nothing AndAlso Not String.IsNullOrEmpty(overlayNode.InnerText) Then
        overlayInput = Integer.Parse(overlayNode.InnerText)
    End If
    ' Πάρε το ενεργό (PGM) input
    Dim activeNode As XmlNode = root.SelectSingleNode("/vmix/active")
    Dim activeInput As Integer = -1
    If activeNode IsNot Nothing Then
        activeInput = Integer.Parse(activeNode.InnerText)
    End If
    ' ➕ Κανονικά labels
    ' ➕ Όλα HG μαύρα
    API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG1.Text", Value:="black")
    API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG2.Text", Value:="black")
    API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG3.Text", Value:="black")
    ' ➕ Ανάλογα το overlay input → ONAIR + κόκκινο
    If overlayInput = 1 Then
        API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG1.Text", Value:="red")
    ElseIf overlayInput = 2 Then
        API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG2.Text", Value:="red")
    ElseIf overlayInput = 3 Then
        API.Function("SetTextColour", Input:="Quadsplitt_Rotlicht.gtzip", SelectedName:="HG3.Text", Value:="red")
    End If
    ' ➕ Ανάλογα το active input → PGM Kx
    If activeInput = 1 Then
    ElseIf activeInput = 2 Then
    ElseIf activeInput = 3 Then
    Else
        Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUR.Text") = ""
    End If
    Sleep(200)
Loop
Kamera 1 to 3 labels are meant to be red if one of the specific inputs is on overlay 1 while label PGM takes k1 to k3 values if any of the 3 specific inputs is active
streamfuchs
#3 Posted : Friday, May 9, 2025 9:52:17 PM(UTC)
streamfuchs
Germany
thanks for the script.
Yes, this is working, but do you think it would be possible, to have the Tally indication as red marked labels, either when the input is on overlay or when the input is switched directly to the output?
nikosman88
#4 Posted : Friday, May 9, 2025 11:59:07 PM(UTC)
nikosman88
Greece
See this version if fits what you need
Code:
Do While True
    ' Get active (PGM) and Overlay1 inputs
    End If
    End If
    ' Reset all HG colors to black
    ' Camera 1
    Dim cam1_text As String = "Kamera 1"
    If activeInput = 1 And overlayInput = 1 Then
        cam1_text = "Kamera 1 is ON AIR and Overlay1"
    ElseIf activeInput = 1 Then
        cam1_text = "Kamera 1 is ON AIR"
    ElseIf overlayInput = 1 Then
        cam1_text = "Kamera 1 is on Overlay1"
    End If
    Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOL.Text") = cam1_text
    ' Camera 2
    Dim cam2_text As String = "Kamera 2"
    If activeInput = 2 And overlayInput = 2 Then
        cam2_text = "Kamera 2 is ON AIR and Overlay1"
        cam2_text = "Kamera 2 is ON AIR"
        cam2_text = "Kamera 2 is on Overlay1"
    End If
    Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextOR.Text") = cam2_text
    ' Camera 3
    Dim cam3_text As String = "Kamera 3"
    If activeInput = 3 And overlayInput = 3 Then
        cam3_text = "Kamera 3 is ON AIR and Overlay1"
        cam3_text = "Kamera 3 is ON AIR"
        cam3_text = "Kamera 3 is on Overlay1"
    End If
    Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUL.Text") = cam3_text
    ' Show which input is on PGM (top right label)
    Dim pgmText As String = ""
    If activeInput = 1 Then pgmText = "PGM K1"
    If activeInput = 2 Then pgmText = "PGM K2"
    If activeInput = 3 Then pgmText = "PGM K3"
    Input.Find("Quadsplitt_Rotlicht.gtzip").Text("TextUR.Text") = pgmText
    Sleep(200)
Loop
streamfuchs
#5 Posted : Saturday, May 10, 2025 12:33:17 AM(UTC)
streamfuchs
Germany
yes thank you very much, this is what I want to use.
One last question when possible:
Could you exchange the obviously cyrillic expressions against english expressions?
That would make it much easier for me to integrate it into my workaround.
Thanks a lot in advance.
nikosman88
#6 Posted : Saturday, May 10, 2025 1:25:21 AM(UTC)
nikosman88
Greece
Hi, thanks for your feedback! Just to clarify — the expressions you mentioned were actually written in Greek (not Cyrillic). I've now updated all comments in the script to English for easier integration.
streamfuchs
#7 Posted : Saturday, May 10, 2025 8:52:20 AM(UTC)
streamfuchs
Germany
Thanks a lot.
That makes it much easier for me to implement.
And sorry because of my error with reference to greek and Cyrillic.
