Feature Requests
Set text via API into title presets
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
It would be really useful to allow not just selection of the index of title presets via API but actually setting the text in them as well. It's so close to that right now, only limited to the live title slot.
I realize that there's capabilities to use data sources but this is needed for me due to a live data stream on network that vmix is intercepting.
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Can you elaborate as to what you're not able to do?
"SetText" is already a shortcut.
That shortcut also accepts the "SelectedIndex" and "SelectedName" parameters to set the text to a specific text field within a title.
Quite honestly I don't recall.
I've been using those shortcuts so I'm not sure what the issue was.
Thanks, though, for replying.
Fritz Golman RadioDNA
Feature Requests
