mataohave
#1 Posted : Thursday, April 10, 2025 10:29:33 PM(UTC)
mataohave
China
I’d like to suggest a new feature for a future update: the ability to cycle through different Mix outputs (e.g., Mix 1, Mix 2, Mix 3) using a single shortcut key, instead of needing a separate key for each one.
Right now, if I want to switch between different multi-view outputs, I have to assign a unique shortcut for each Mix. It would be much more efficient if we could set up one shortcut (e.g., F1) to toggle or cycle through predefined Mix configurations.
Example use case:
F1 press #1 → Output switches to Mix 1 (Main stage)
F1 press #2 → Output switches to Mix 2 (Player cam)
F1 press #3 → Output switches to Mix 3 (Break/Ad scene)
F1 press #4 → Loops back to Mix 1
This would greatly simplify live production setups where multiple Mixes are used and operated by a single operator.
Would love to see this added in a future version. Thanks for the amazing work!
spinfold
#2 Posted : Thursday, April 10, 2025 11:53:15 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
This is very simple using Companion!
