Help for a beginner who would like to write simple scripts
Good evening, first of all I am not a programmer but I would like to learn slowly and so I am trying with visual basic to create some scripts for Vmix. As a test script I am trying to make it so that when I press the v key on the keyboard the output switches from camera 1 to the first video contained in a list. The script code however seems to absolutely not want to digest the End Sub closure, even if it seems to be regular. Who can help me? This is the code: Tks Andrew
Dim HD_Webcam_PC_Frontale As String = "HD Webcam PC Frontale" Dim listInputName As String = "List" ' Assicurati che il nome della tua lista sia proprio "List"
'-- Imposta la telecamera all'inizio API.Function("CutDirect", Input:=HD_Webcam_PC_Frontale)
'-- Gestione degli eventi della tastiera Sub OnKeyDown(Key) If Key = 86 Then ' 86 è il codice ASCII per il tasto "v" API.Function("ListPlayIndex", Input:=List, Value:="0") ' Riproduce il primo video (indice 0) End If End Sub
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: visioneimmagine  Good evening, first of all I am not a programmer but I would like to learn slowly and so I am trying with visual basic to create some scripts for Vmix. As a test script I am trying to make it so that when I press the v key on the keyboard the output switches from camera 1 to the first video contained in a list. The script code however seems to absolutely not want to digest the End Sub closure, even if it seems to be regular. Who can help me? This is the code: Tks Andrew
you can not have subs or functions within a vMix vb.net script ! There is post regarding scripting with lots of examples , https://forums.vmix.com/...86-Scripting-for-Dummies
I load this code into the script window, but when I save it it always gives the same error. of end sub. Could you explain to me what you mean then when you say that I must have a script? Why does it not allow me to save it....Thanks a lot
Originally Posted by: visioneimmagine  I load this code into the script window, but when I save it it always gives the same error. of end sub. Could you explain to me what you mean then when you say that I must have a script? Why does it not allow me to save it....Thanks a lot from the help files: vMix Scripting supports the majority of VB.NET 2.0 code that will work within a single sub or function. so i repeat; one can not have subs or functions within a vMix vb.net script Sub OnKeyDown(Key) ... End Sub is the error one can not save a script in vMix if there is an error in the code
sorry if I understood correctly this means that more functions and calls to the PC keyboard or to dialogues with any external programs/interfaces that provide more if then nodes and therefore in fact particular functions are not possible? But there is no way to interact with Vmix in a more complete way. Sorry but I am a beginner and before I launch into things that perhaps are not possible I would like to have the complete picture of how open Vmix can be to programming. So also to understand how the manufacturers who create HW interfaces that communicate with Vmix or external audio programs to Vmix do it. Tks
Originally Posted by: visioneimmagine  sorry if I understood correctly this means that more functions and calls to the PC keyboard or to dialogues with any external programs/interfaces that provide more if then nodes and therefore in fact particular functions are not possible? But there is no way to interact with Vmix in a more complete way. Sorry but I am a beginner and before I launch into things that perhaps are not possible I would like to have the complete picture of how open Vmix can be to programming. So also to understand how the manufacturers who create HW interfaces that communicate with Vmix or external audio programs to Vmix do it. Tks
If you need more complicated things,you can do an external program and when it comes to vmix action,you can use the http or tcp api to send the command in Vmix
