Ash
#1 Posted : Saturday, January 31, 2015 5:32:09 PM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi Martin
I would like to get at least one cam working with this on my ASUS G750 JZ
The CPU is a 4100HQ @2.4GHz 8 cores, however it has a feature called TurboBoost which ramps up the clock as the load is increased.
Is there any solution in this case to at least meet the minimum requirements and get the app to start?
Cheers
Ash
Len56
#2 Posted : Sunday, February 1, 2015 1:59:35 PM(UTC)
Len56
Hi I have a Asus P6X58D-E which uses the Asus EPU-6 engine utility which uses TurboBoost and I just set mine to High Performance in the EPU-6 engine utility, I find that works very well for use with Vmix but I also have a Intel Core i7 950 @ 3.07GHz Processor and 16GB of RAM plus the Asus GTX 760 2GB graphics card.
Hope this helps.
Len.
