mheld
#1 Posted : Sunday, March 16, 2025 7:54:32 PM(UTC)
mheld
Germany
I have been using vmix for live streaming productions for over 5 years. We work outdoors, so a quick change in weather and lighting conditions can always happen. Due to the work situation, the correction cannot be made on the computer. Would it be possible to have the controls for colour correction in the WEB-UI as well? That would make the workflow much easier for me.
Basically, all you need to do is select the input, correction on/off, and slide switch for gain R/G/B.
