DaveT
#1 Posted : Wednesday, March 5, 2025 10:49:07 AM(UTC)
DaveT
Heya,
The Zoom audio is currently 32khz only, which has been more of a Zoom limitation.......or WAS
I have learned that 48khz is now possible (other end would need to enable "Original Sound"), but the VMIX Zoom plugin doesn't seem to be updated to support it.
48khz support would be an awesome update to the VMIX Zoom plug-in.
ZommISO is about to support it in v2.31, and trying to avoid avoid having to go back to using it.
DT
#2 Posted : Wednesday, March 5, 2025 10:59:17 AM(UTC)
vMix always sends 48khz to Zoom and receives the audio at whatever sample rate Zoom receives.
vMix also selects high fidelity mode when Original sound for musicians is ticked.
So as far as we are aware, everything in vMix is ready to receive 48khz, so any limitations may either be a) an unreleased Zoom feature or b) the source is not sending 48khz
