jaialai
#1 Posted : Tuesday, February 25, 2025 10:38:39 PM(UTC)
jaialai
Views messages in topic : 45
I wanted to ask a question about a topic that has been giving me problems for some time.
When I create labels with the speaker's name, place of work, etc. I create a master tag with GTitler and then import it into VMIX. The master label appears there and, to add another speaker, I click edit and mark the name of the first speaker and give it + (add) and it adds a second line with the same data as the first. I edit the fields of that label and do the same for the next label, press + (add) and edit...
do you do it like that?
It works fine for me this way, but the problem I have when I'm already on work day is that, sometimes, if I have to edit the titles created due to some last-minute change, it usually happens that even though I edit them and save them (closing with the X), the updates are not recorded.
It doesn't always happen but there are times when it annoys me a lot.
