sackboydad
#1 Posted : Sunday, February 23, 2025 2:36:23 AM(UTC)
sackboydad
[img]Please add the ability to offer a waveform monitor for each input (maybe as a virtual input for the input, except instead of showing the video it shows a waveform monitor).
We need the ability to shade our cameras without having to select on preview. OBS has a plugin that does this very thing. Would never us OBS as vMix is 100 times more stable. HOWEVER, we DO use OBS to get waveform monitors. I use the cameras' NDI feeds in OBS, which go through their Video Monitor plugin, generate Waveform Monitors, then send each of those generated waveform monitors out in individual NDI streams. Those NDI streams are used in vMix as inputs. I ten arrange them so they sit underneath the camera. Sadly has any impact on PC performance (the both run on the same PC). However, because of all the "round-tripping" there is over 1/2 second of delay. For a waveform monitor, who cares?
But it would be REALLY nice to have built-in to vMix.
thank you
[/img] Control Room.jpg (3,924kb) downloaded 12 time(s).
thanks 1 user thanked sackboydad for this useful post.
bulent_atlas on 3/8/2025(UTC)
