Feature Requests
Feature request: Scoreboard OCR support
Thanks: 4 times Was thanked: 13 time(s) in 4 post(s)
Add Scoreboard OCR capability onto an input for capturing scoreboard digits and sending them to a title graphic. Much like Scoreboard-OCR software does, only built in to vMix. Could be an additional buy-in if necessary. Would eliminate the need for "bolt on" software products.
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 171 times Was thanked: 3 time(s) in 2 post(s)
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: kricher1964  Add Scoreboard OCR capability onto an input for capturing scoreboard digits and sending them to a title graphic. Much like Scoreboard-OCR software does, only built in to vMix. Could be an additional buy-in if necessary. Would eliminate the need for "bolt on" software products. Can you show me "bolt on" one that is fast enough to catch stopwatches without gobbling up to much resources;-)
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
We have been using Scoreboard OCR for several years for futsal and floorball. It runs on a separate Intel Nuc Hades Canyon with an .M2 SDI IN Card and controls the various vMix graphics. I think it makes sense to run it on a separate device. Sometimes, for example, the camera in a sports hall gets misaligned, or we have to move it because something has been placed in front of the display and the camera can no longer see it (last time it was a branch hanging down from a tree). In this situation, I'm glad we can continue to use vMix to broadcast the game while someone else takes care of fixing the Scoreboard OCR until it's working again.
Feature Requests
