jomo
#1 Posted : Friday, February 7, 2025 3:59:29 PM(UTC)
jomo
Dear all,
I am looking for a script that allows me to do the following: As soon as a video list is started, a countdown should be displayed in a separate input (which can be displayed in multiview), which starts with Transition In, and then ends when the respective video is finished. This should show directly how long the respective video is still running. Is there already a code for this? Thanks!
#2 Posted : Friday, February 7, 2025 7:37:31 PM(UTC)
Originally Posted by: jomo Go to Quoted Post
Dear all,
A forum search : https://forums.vmix.com/...ndividual-clip-countdown
the vMix api shows the duration and position of the current running clip , a bit of math will give you the data
