vMix28: 'vMix Output1" No Longer Visible as NDI Source Inside vMix
Joined: 3/23/2020(UTC) Posts: 140  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
I've noticed in vMix 28 that when selecting "vMix Output 1" as an NDI source inside of vMix, the input comes up blank.
Output 1 IS visible externally, in an NDI viewer like Studio Manager. You just can no longer see it inside of vMix.
For several years I've kept an NDI input in my vMix presets with vMix Output 1 as the source. I've used this input as a layer for various custom multiviews and return feeds. I started this before there was an actual OUTPUT input.
But after upgrading to vMix 28 this no longer works. It's not a big deal. An easy switch to replace with an OUTPUT input.
But I am curious if this in a desired behavior with the update or a bug?
Thanks,
Greg Gibson
Hello. I just tried at version 28.0.0.35 and it work ok. Do you have any specific scenario/workflow to re-plicate the bug?
This issue has resolved itself for me. No idea what was causing it but it has cleared up.
