Give the ability to enable Telstrator for individual Callers.
You have been a member since:: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Technically, they did.
Use a Mix for your Output. Route the overlay to that Mix.
That's pretty much the only way something like this would be implemented anyway and it's already an option.
I want my Callers to mark up the screen.
I don’t think what you’re saying would make the Telestrator UI show up for the Caller, would it?
Originally Posted by: jpink  I want my Callers to mark up the screen. That wasn't how I read your original request. Apologies. The Telestrator is controlled through the Web Controller interface. The same mechanism by which you can achieve external control with the Web Controller should allow you external control of the Telestrator. Any other option probably won't be particularly feasible short of using a third party program independent of vMix and vMix Call.
 1 user thanked WaltG12 for this useful post.
Originally Posted by: WaltG12  Originally Posted by: jpink  I want my Callers to mark up the screen. That wasn't how I read your original request. Apologies. The Telestrator is controlled through the Web Controller interface. The same mechanism by which you can achieve external control with the Web Controller should allow you external control of the Telestrator. Any other option probably won't be particularly feasible short of using a third party program independent of vMix and vMix Call. You're right, I should've made my original thought more clear when typed out. I want my Callers to mark up the screen without having to open a 2nd tab and access the Web Controller Interface, similar to how Zoom allows annotation. Not a deal breaker by any means, but since this is the Feature Request section, figured I'd lob it in here ;)
