Joined: 2/25/2022(UTC) Posts: 3  Location: Manchester Thanks: 1 times
I set up a shortcut to be used in the telestrator so that I can turn on and off bus b and the master output. But I cant tell if the busses are on or off when I press the button. In other applications I would set up an activator for the button so it turn red when on. is there anything like that for the telestrator?
