3rd Party Software and Development
Vmanager and vScheduler-vmix list input drag n drop for videos
Hello guys. Have a nice year 2025. A feature request that many people ask is the abillity to easy re-arrange the items inside a list input. As we wait for this i personally thought if there is a workaround,so i made an external solution. I took the known vscheduler-vmanager code https://forums.vmix.com/...ler---vMixScheduler-Fork and i added drag n drop support for video files. Drag n drop or insert-copy-paste your video files and then select them and either export an m3u list or press the vmix videolist input and the list will be added directly to vmix Some notices for button vmix videolist input 1.It uses the vmix http api commands and for now is hardcoded to localhost vmix pc.That`s why in the vmanager folder has been the file Mono.HttpUtility.dll 2.It creates a txt file in vmanager videolists folder. This for a future version i started to implement and it will be used to save if we have "in-points" in vmanager and restore them into vmix 3.The button returns the total list duration as it takes it from vmanager. So no "select index" in vmix and the list is ready to playout. The total list duration may have some seconds difference on what vmanager gives and vmix says. Also if we have in-points in vmanager the total duration will be shown by calculating them. And finally there is allready mentioned when an mxf file is on list input https://forums.vmix.com/...31792-MXF-File-Metadata. Vmix cannot take and show it`s duration when not play it. So if we send an mxf file,the total list duration in vmix will be all other videos minus mxf file and the correct will be from vmanager 4."Always on top" check button to help in the drag n drop from windows explorer Disclaimer-->im not a programmer. I used AI and some hour for try and test to make the program. Hope someone finds usefull the program. https://www.dropbox.com/...amp;st=4nfgsyv2&dl=0 vmanager-list input.png (40kb) downloaded 107 time(s).
 1 user thanked nikosman88 for this useful post.
Hi. I realized now that dropbox link may not was public. I had a request for approve download before 4 months! Now it is ok for download. Also there exist a new version in testing mode for anyone interested to to try.
