Audio Delay Parameter Missing in Stream Settings
Joined: 11/10/2024(UTC) Posts: 8 Location: Corvallis, OR
Because we are using an ASIO patch bay and various other ASIO devices integrated with our vMix production, and because vMix is forcing such a large ASIO buffer, there is a significant audio delay with our productions (60ms). The output recordings have that solved as they have a parameter to offset the audio, and we use an offset of -60 to get it back in sync and it works great.
But for live streams, there is no parameter to offset the audio. Is this an oversite?
