Ed789
#1 Posted : Saturday, January 4, 2025 3:47:41 AM(UTC)
Ed789
We typically play three commercials during our broadcasts that is contained in a list-view input, and I’ve set up a trigger shortcut to handle muting and unmuting the commentator's audio during these commercials.
The current setup works like this:
On transition in: The commentator's audio is muted.
On transition out: The commentator's audio is unmuted.
This system has been working great with no issues as long as the commercials play all the way through.
However, we occasionally need to cut a commercial short and return to our cameras before the video ends. When this happens, the commentator’s audio doesn’t get unmuted because the video hasn’t completed its full run.
Is there a better way to handle this issue, preferably without using scripts?
Thanks in advance for your help!
Best,
Eddie
nikosman88
#2 Posted : Saturday, January 4, 2025 4:00:28 AM(UTC)
nikosman88
Greece
Hi. Something wrong with your setup. This process i use it in daily basis. Check if beyond "on transition out", you have "on completion" or any wrong naming. The "transition out" work ok for the action we need to do, at any time we cut out the list or other input
Guest (4)
