jared.quinn
#1 Posted : Friday, December 20, 2024 3:05:37 PM(UTC)
jared.quinn
Instant Replay: Reverse + Play Events does not behave as expected - When Reverse is selected before an event is played, playing the event should go from OUT to IN.
To reproduce the problem.
Setup a replay input.
Mark several events in & out.
Select an event.
Select reverse.
Select play event.
The event starts playing from the IN point and continues playing back from there.
This does not feel like the desired behaviour when in reverse mode; it would make more sense if the event still played as an event (still contained by the IN/OUT markers) but playout commencing at the OUT and playing in reverse until the IN mark.
Toggling direction should still behave as it does now while playing a clip.
Believe it or not I've needed to play out clips in reverse twice in the last 3 months for different clients and this has caused me issues!
#2 Posted : Friday, December 20, 2024 5:05:43 PM(UTC)
Select an event.
Select reverse.
Select play
Why, for now,add a jump to end of event first before play? Create a play reverse shortcut as such
