Joined: 9/14/2024(UTC) Posts: 9  Location: Sydney Was thanked: 2 time(s) in 2 post(s)
It would be handy to be able to use the full inputs UI, tabs and search to control the additional vMix mixes apart from the primary M/E.
This could take several forms; a button on Mix inputs that turns the default pv/pgm into pv/pgm for that mix (possibly with a visual indication around the pv/pgm windows) or a dropdown/buttons between the pv/pgm windows where one could select the mix you are viewing in pv/pgm and controlling with the transition buttons and previewing content as you would on your primary mix.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
