Feature Requests
Shortcut for Play Each Angle of Selected
Joined: 5/20/2017(UTC) Posts: 62   Location: Philippines Thanks: 170 times Was thanked: 3 time(s) in 2 post(s)
Play Each Angle of Selected is available in Instant Replay window, Play Events button. Please add shortcut because couldn't find one.
Thank you, Mon
Originally Posted by: monamiga  Play Each Angle of Selected is available in Instant Replay window, Play Events button. Please add shortcut because couldn't find one.
Thank you, Mon Have a look at https://www.vmix.com/hel...erInterfaceOverview.htmlEspecially the indication of "Select Camera Angles to play for each event" The means any little square that is fully white will be played back , so the play all the angles from an event they all have to be white with the available shortcuts one can select each camera, turn on and off or toggle. D that for each camera angle and you can pay them all with the play events button
Feature Requests
