RedSevens
#1 Posted : Wednesday, November 27, 2024 5:51:42 PM(UTC)
RedSevens
Romania
On the Stream Settings, for a custom RTMP server it would be great to have the posibility to completely remove the network buffer. Currently, from the dropdown menu the minimum you can choose is 5 seconds, which is very annoying for our case.
