Joined: 11/22/2024(UTC) Posts: 2  Location: Michigan Thanks: 1 times
I was wondering if it is possible to have a resolution of 1366x768 fr 59.79 in vmix my dartboards are putting out this res. and vmix will not recognize it. Thanks
Joined: 10/31/2020(UTC) Posts: 203  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
What capture card are you using? vmix should support any resolution and framerate that is supported by your capture card.
