romromillys
#1 Posted : Monday, November 18, 2024 9:53:11 PM(UTC)
romromillys
Austria
Black screen problems have started occurring when I use the vMix Desktop Capture feature. Every time I try to share my desktop, the source is detected, but the screen stays black in vMix.
Updated both vMix and Desktop Capture to the latest versions.
Checked my network connection, which seems to be fine.
Restarted both my PC and the vMix software.
Unfortunately, none of these steps have resolved the issue. Has anyone faced a similar problem? Could it be related to graphics settings, network configuration, or something else I might be overlooking?
Any advice or suggestions , please share with me, Thank you.
#2 Posted : Tuesday, November 19, 2024 10:24:13 PM(UTC)
Was thanked: 508 time(s) in 477 post(s)
@ romromillys
What "Window Capture Method" have you selected from the dropdown menu at the bottom of the "Local Desktop Capture" set-up screen?
(you may need to experiment with the various options to find the one that works best for your situation)
