I work in greenscreen studio. I use virtual sets in vmix. https://www.vmix.com/hel...ndex.htm?VirtualSet.htmlWe use 4K cameras, my preset is 4K and output - what is streamed on internet is FULL HD. So I work with zooming in 4K virtual set. That is usefull because you dont need guy behind cameras, you do this virtually and 4K inputs give you possibility to use different so called angles in virtual sets. Now there are four small windows representing 4 angles. These contains snapshots of particular scene of virtual input which are static and they update only after in "setup" of virtual set you switch any layer off and on. I am adjusting these angles always during live show because I have to react on positions of people on scene - they moves sometimes. Problem is I dont have these preview windows updated in real time, nor automatically. I have always to manually do this action with switching on/off some of layers. I can live with that but event automatically updated previews in these windows would be nice upgrade. Thank you.
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
+1 ok i believe it is difficult and out of cost to have an "axximetry" type virtualset inside vmix,but i think the current system can have improvements
Originally Posted by: nikosman88  +1 ok i believe it is difficult and out of cost to have an "axximetry" type virtualset inside vmix,but i think the current system can have improvements I think it could be great something like Adobe Ultra (I miss a lot an update of that great software).
i set trigger so it will automatically set layer visible on/off (switching two layers between them), so it update scene previews every time I cut. maybe It could be easily scripted do this proces every 5 second or smtg like that...
