	Feature Requests
	Keeping Settings Pop-out Window Open
 Joined: 12/30/2020(UTC) Posts: 7  Location: Madison, WI Thanks: 3 times
                Hey guys:
  One thing that continues to be a problem for me. The settings window pop out. I need to go in and make changes on the fly, which means that I have to open the settings window, make a change, then close it to do things on the vMix windowg.
  "Shortcuts" are the main reason I want the settings box to stay open. And not as much for this machine, but when I'm on the road with a single screen, the settings window usually blocks the main window. So if I'm trying to set up a trigger, and forget which number I'm triggering, I have to close out of settings to see the screen, then go back in.
  Triggers and scripting are other reasons why I need the settings box to stay open at times.
  Is there a way to fix this, or move those three settings to a pop-up that can stay open?
  attach]5765[/attach]
	Feature Requests
