I'm slowly learning VB.net, in order to help in scripts and also build a simple app to update some basic stats during my sports live streams. The stats are stored in .json files and I need to find a way for VB.net to access them and update some fields.
I learned a way to do that with VB & .txt files, but between VB & .json the only way I've found is with .json having ... a single line of data. For anything more than that the "Do While Not EndOfStream" option doesn't seem to work.
Can somebody help ?
