How to change from MAX to Pro or 4K
Joined: 6/6/2016(UTC) Posts: 19   Location: The Netherlands
Is it possible to go from a vMix MAX subscription to PRO or 4K, without loosing templates or other settings?
Is it as simple as filling in the new Key?
Originally Posted by: rambouzi  Is it possible to go from a vMix MAX subscription to PRO or 4K, without loosing templates or other settings?
Yes Always save your presets and export config regardless
Thank you!! That's all a need! 👍
