mirror image external output
Joined: 2/25/2022(UTC) Posts: 3  Location: Manchester Thanks: 1 times
We have two screens in our sanctuary. One of them is in the front where we are sending Fullscreen images of slides and videos. the other is in the back of the room and we are using it as a monitor for the presenters. I have that set up as an external output so they can see everything we are broadcasting. The image is backwards for the presenters and I would like to reverse it. I cant find a way to set the external output up as a mirror image. Is this possible?
I have looked at the decklink Duo video card which I am sending the external output to, but don't see any mirroring settings there.
Hello. A way is Add input-->output-->mirror this input and set it to output into external via your decklink
 1 user thanked nikosman88 for this useful post.
Originally Posted by: nikosman88  Hello. A way is Add input-->output-->mirror this input and set it to output into external via your decklink Thanks. This worked perfectly, and I figured out how to use external 2.
