vMix Call Local Capture/Record
Joined: 11/12/2020(UTC) Posts: 10  Location: Fort Lauderdale
While platform such as Riverside and Squadcast are gaining traction, they simply just can't compete with the high caliber features offered by vMix. Please find a way to integrate local capture for callers to save or upload their feed. This would serve as a failsafe for the host to feel confident that if their stream runs into glitches or failure, the local stream will be native. And the audio quality will be superior to the 64kbps that vMix call currently caps at. Please please please consider this feature. It will be much appreciated by many as I see that there have been several requests in recent years.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
vMix has set up a separate forum just for feature requests like yours. Visit the Feature Request forum to search if your idea has been already suggested. If not, please submit it there. Yours might just be the next great new feature for vMix. - Tom
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Use Max on the Caller's end.
Problem solved.
