barryondeck
#1 Posted : Thursday, October 24, 2024 12:07:51 PM(UTC)
barryondeck
Unless I just don't know how to do so, the fact that you can not copy and past formatting from one object/element to another in GT title designer is absolutely maddening. Sometimes I feel like I'm working in MS Paint on Windows 3.1
Why on earth is this not possible?
I'm having to redo the formatting of a title that has 19 names and scores that is fed dynamically via a google sheet, and I'm having to go in and change the formatting on 38 different elements individually because I can't just
a) select all and choose a different font and font size
or
b) use a format painter and just click on them to change their font and font size etc...
I've had to do this several times now and each time I curse this software and get ever so close to quitting streaming all together.
This is so stupid.
#2 Posted : Thursday, October 24, 2024 5:52:54 PM(UTC)
or
This is so stupid.
A bit of a shortcomming i agree but there is a workaround if this is something that needs to happens often:
Specify a font and a size to your text items in your title within the designer
Save the title as a GTXML instead
open this file in wordpad and to a find/replace of the fontnames and sizes ( can be automated with a script or small self created app )
WHile a shortcomming , access to a source is also handy for personalisation ;-)
barryondeck
#3 Posted : Friday, October 25, 2024 12:37:12 AM(UTC)
barryondeck
or
This is so stupid.
I oh wow, had no clue about this. Will give it a try. Thanks Doggy! Been using vmix for over 4 years and consider myself a power user and still learn new did all the time.
Appreciate the tip!
