How to send video signal from Vmix to analog transmitter?
Joined: 10/22/2024(UTC) Posts: 1  Location: Nakhon Ratchasima
I would like to know how to send video and audio signals from Vmix to an analog TV transmitter because I am going to buy an RF modulator where the Vmix signal must be sent to the transmitter.
You need a card or adapter that takes the external out from vmix and converts it to analog signal. Personally i have the blackmagic intensity 4k pro card that has analog (rca/s-video/composite) cables that you can connect in an analog source. Or other solution (if you allready have an external card that gives hdmi out or sdi) take a (cheap but also crap) hdmi/sdi to analog converter to do the connection. Now if need RF modulator because the analog tv transmitter doesnt have rca/scart connection input connection and only RF you need a proper adapter
