Feature Requests
Allow for SRT Inputs to be saved per stream, not per server.
Joined: 9/7/2024(UTC) Posts: 38  Location: The Great PNW Was thanked: 4 time(s) in 4 post(s)
Within the Add Input or Change screens for SRT Inputs, the interface only saves one entry per server. That means if I have the following inputs:
- srt.domain.com:12345?streamid=application/stream-id-1 - srt.domain.com:12345?streamid=application/stream-id-2 - srt.domain.com:12345?streamid=application/stream-id-3
...the interface will only save a single entry for srt.domain.com. This means if you have to reconfigure any one of those entries, they do not display and populate the boxes unless they are the last entry to be entered. This means you can loose relavant information to that stream you're wanting to edit, but you will need to have it stored somewhere else for reference as you will never be able to recall them through the current interface.
All entries should be saved individually and presented in a way to which you can identify them individually based off any one of their parameters, as you may have multiple from the same server.
Thanks for considering this correction to your GUI!
Feature Requests
