Hi, I'm new to vMix and am trying to use audio busses. I have set the A and B bus to virtual audio cables, but I have also tried other sources. No matter what I pick, when I set a source to go to the Audio Bus A or B neither of their meter bars move and there is no output on either source. I can hear the audio on the Master channel and in my headphones just fine, so I am unsure what I am doing wrong.
[img=https://imgur.com/XJjUVGQ]Audio Bus Config[/img]
[img=https://imgur.com/eJrv1Cw]No audio on Bus A[/img]
Am I missing a step?
Joined: 2/23/2023(UTC) Posts: 85  Thanks: 28 times Was thanked: 20 time(s) in 6 post(s)
Check the bus mixer for input 17 to ensure that the fader isn't all the way down. Also make sure the channel mapping is correct.
