Pavel
#1 Posted : Monday, August 12, 2024 2:13:00 AM(UTC)
Pavel
Please help me. I have a problem with the commands in the script.
I use ReplayMoveSelectedEvent and ReplayCopySelectedEvent in the script.
"Function=ReplayMoveSelectedEvent&Value=4"
I would like to move or copy all the marked ones, for example 3 out of five, to other events. After the command, only the first marked record is copied or moved. What do I need to modify in the script?
Thank you very much for your help.
StanTV
#2 Posted : Monday, October 7, 2024 9:39:43 PM(UTC)
StanTV
Ukraine
I have the same problem. It used to work without problems. I selected the necessary repetitions and through the hot key it will move to the necessary folder through the command ReplayMoveSelectedEvent. Now this function moves only one repetition. It is very inconvenient. I have to do it manually with this mouse. Tell me what can be done. Where to go?
