videokommando
#1 Posted : Tuesday, August 6, 2024 10:09:15 AM(UTC)
videokommando
Work with vMix as if you were using Atem ISO recording mode and get time line in EDL format.
1. Prepare the hotkeys for the inputs
2. Record the inputs during the live broadcast
3. Convert the log file to EDL
4. Import the EDL file into your editor
5. Enjoy fast workflow
Save 3-5 working hours a day with just a few clicks.
You can use multicorder or even external recorders.
You can also try the full-featured demo version of the converter without registering. In demo mode, the converter processes the first 10 minutes.
Here you can find the converter and the description.
https://log2edl.com/
I got a lot of help from this community, so I would like to give you a special coupon. You can try the one month subscription for $1.
coupon code: vmixforum
coupon valid until 31 Aug 2024.
abwvideo
#2 Posted : Friday, August 23, 2024 2:37:27 PM(UTC)
abwvideo
Does it work with Final Cut Pro? I don't see a mention of FCPX on the website.
videokommando
#3 Posted : Tuesday, August 27, 2024 12:20:55 AM(UTC)
videokommando
As far as I know, Final Cut does not support reading EDL.
You can convert the EDL to XML with free Davinci Resolve and FCP can import xml.
Guest (4)
