Soapm
#1 Posted : Friday, July 12, 2024 4:25:25 AM(UTC)
Soapm
I noticed the FFMPEG that runs with vMix says 32 bit in task manager (Win10). Is there anyway to make it run on our 64 bit version that's loaded on the machine (c:\ffmpeg\bin\).
Not sure what difference it'll make but trying to take some load off the machine.
dingonbel
#2 Posted : Thursday, October 16, 2025 4:06:22 AM(UTC)
dingonbel
Brazil
Good afternoon. I'm thinking about doing this for the same reasons. Can you give me more information if it solved your problem?
Sincerely,
Diniz
