Instant Replay
Why exports have Doubled duration (solved)
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
WHy would as AVI exported clips have a doubled duration then as mp4 exported and have their "second half" part as a frozen frame ?
IR and project fps are set the same. Doesnt seem to be related to the actual cameras used
[Solved] Audio channels selection was set to 2 instead to 4 (Per vMix support, to be fixed in next update)
Instant Replay
