kaduramos
#1 Posted : Thursday, June 13, 2024 3:37:35 AM(UTC)
kaduramos
Rank:: Member
Brazil
Was thanked: 11 time(s) in 5 post(s)
Hi guys
Anyone know if have another device usb ou thunderbolt to work on laptops to use external
I only find the blackmagic ultrastudio monitor that is thunderbolt
Have another option??
fenki86
#2 Posted : Thursday, June 13, 2024 7:03:28 PM(UTC)
fenki86
The Blackmagicdesign Ultrastudio SDI would be a possibility (although they don't sell that particular model anymore). You might get one of a reseller.
The Magewell X100 is another option.
Both of them could bring in a signal via SDI (the magewell also offers an alternative with a HDMI-Input).
There are plenty others, I had both of the above mentioned and worked with them in vMix.
thanks 1 user thanked fenki86 for this useful post.
kaduramos on 6/14/2024(UTC)
#3 Posted : Thursday, June 13, 2024 9:08:46 PM(UTC)
@ kaduramus
vMix only supports specific cards from AJA, Blackmagic and Bluefish for external Output as listed on the Supported Hardware page:
- https://www.vmix.com/sof...are.aspx#capturehardware (anything listed as I/O, IN/OUT, In or Out, OUT or Output)
- https://www.vmix.com/help27/ExternalOutput1.html
kaduramos
#4 Posted : Friday, June 14, 2024 1:07:17 AM(UTC)
kaduramos
Rank:: Member
Brazil
@fenki86
this Magewell x100 is thunderbolt or usb connection? Do you use on a laptop??
I cna't find in anywhere to see or buy
where you bought?
fenki86
#5 Posted : Thursday, June 20, 2024 7:33:37 PM(UTC)
fenki86
Originally Posted by: kaduramos Go to Quoted Post
@fenki86
where you bought?
a customer which I helped producing some livestreams bought 2 of those devices a couple of years ago at a german reseller. I don't know if they are still listed there.
