Famous
#1 Posted : Thursday, June 6, 2024 9:03:54 PM(UTC)
Famous
Nigeria
I wish to know if it is possible to trigger a XML data source on VMIX.
I was able to send and connect my Bibleshow scripture XML data on PC2 to the Vmix Title i designed on GT designer over network but i need a way to trigger it so that when i click on a bible passage on Bibleshow, it automatically overlays as lowerthird and transition-out when i close the bible.
Screenshot 2024-06-06 115531.png (494kb) downloaded 16 time(s).
nikosman88
#2 Posted : Thursday, June 6, 2024 9:56:56 PM(UTC)
nikosman88
Greece
Hello. When you not send is blank or anything else that remains same when you close the bible in this input? If yes you can maybe do a script that will read if there is or not content on the text field of the title and procced to the action you need. Some examples for this are in the "scripting for dummies" thread https://forums.vmix.com/...86-Scripting-for-Dummies in the forum and here https://www.tvcrew.ch/vm...sAouSv22uTU_3dDkvL5TyzTs that is based in the forum examples
