VMix 27 Aspect Ratio Problem
Joined: 11/25/2023(UTC) Posts: 2  Location: Los Angeles
I have a playlist that plays both SD (720x480) and HD (1920x1080) videos, in our previous vMix 24 version, when we enable 'widescreen' in the aspect ratio, the SD videos that have 4:3 aspect ratio is automatically stretched to fill-in the widescreen 16:9 and retains the HD Videos as is, but on vMix 27 this is a different scenario, SD videos are stretched but not enough to fit the entire widescreen (16:9) of 1080p, is there a workaround to this?
Hello. This started from v25 the first version that reads correctly the aspect ratio of horizontal videos. I have allready mentioned this bug in the v26 beta versions https://forums.vmix.com/...x-26-Released#post108640 but this is not fixed until now. The only solution i found is to separate in different lists these videos or zoom in as needed but this also affects the fullhd videos. I hope that in a future version they will fix it
