vjmandala
#1 Posted : Tuesday, May 28, 2024 12:24:25 PM(UTC)
vjmandala
How does one force VMix input Desktop Capture view to refresh the NDI thumbnails to reflect actual/current NDI sources.
At times, the NDI thumbnails will appear as input sources that were sent hours if not days ago.
vjmandala
#2 Posted : Monday, June 2, 2025 3:47:34 PM(UTC)
vjmandala
same same.. be great if realtime thumbs would appear.
I am surprised no one else has commented here on this. It is a real issue, particularly when there are many NDI sources from many PC's. I am teaching VMix atm, with 22 students/PCs all sending multiple NDI sources. Having to scan list for PC names can be tedious when realtime thumbnails could nail it!
Whilst on the topic, would also be great if VMix developers could please make an option to:
- Collapse individual thumbnails and groups of thumbnails ie Audio Outputs, Cameras/Vmix Calls and Video Outputs.
- And the ability to collapse all thumbnails within a computer (or device) so that only computer names appear in list until they are expanded.
- Would be also great if the order they appear in a list can be customized manually.
- And color code PC icons
- finally, creating custom groups of PCs ie Graphics, EVS, Remote Talents, Audio, Stream etc.
mavik
#3 Posted : Tuesday, June 3, 2025 5:46:16 PM(UTC)
mavik
If you have an NDI input in vMix you can right click the input and change the NDI source from the dropdown. Alternatively you can always use the "change" button top right on the input general section and select the source you like.
Collapse inputs: right click on the top of an input
