Paul Camino
#1 Posted : Wednesday, May 22, 2024 5:37:47 AM(UTC)
Paul Camino
I understand the ease of use of vMix call as a web RTC application. But now with alot of PC's shipping with NPUs if not with an NVIDIA GPU. It would be good to be able to take advantage to have Noise reduction, background blur/replacement, and a better ability to stbilize at 1080 or greater (normally WebRTC will run at 720) as well as have some login credentials, so that someone who accientally mistypes in a password that is in use with someone else, doesnt interject. Ideally this is a "portable" app that doesn't require "install" but probably not doable if running AI services.
nikosman88
#2 Posted : Saturday, May 25, 2024 1:42:06 AM(UTC)
nikosman88
You have been a member since:: 12/24/2021(UTC)
Greece
+1
It is something im missing because some android phones (older one) dont get easy to do vmix call permissions easy one push selection. And an app will be great to exist.
Paul Camino
#3 Posted : Saturday, May 25, 2024 3:12:25 AM(UTC)
Paul Camino
A mobile app for android or iOS is a different ask than this. Would still be good to have as well, since mobile phones are now integrating AI Chips into them. My original ask is so that vMix call is not restricted to the limitations of WebRTC, and could have filter properties like background replacement/blur, noise cancelling, or others.
ryxyz
#4 Posted : Saturday, May 25, 2024 7:49:39 AM(UTC)
ryxyz
Rank:: Advanced Member
Was thanked: 20 time(s) in 6 post(s)
From vMix's most recently live stream, they said they are not going to be working on any vMix Call improvements in the near future, and instead focusing effort on the Zoom integration.
Paul Camino
#5 Posted : Saturday, May 25, 2024 7:51:56 AM(UTC)
Paul Camino
Hopefully some Microsoft Teams native support as well. I currently do this with their production tools.
mavik
#6 Posted : Monday, May 27, 2024 9:38:19 PM(UTC)
mavik
I understand the zoom approach and it's nice work. But the other half of the corporate world is using MS Teams and they still have NDI support that I use frequently. It works good so far. But there are chat and or question integration that is missing and might never come due to rights issues within the entire Microsoft Suite
Utocate
#7 Posted : Saturday, November 8, 2025 5:30:10 AM(UTC)
Utocate
Canada
Adding support to the request for Microsoft Teams integration.
